smog pump removal
Old Apr 23, 2004 | 10:58 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
smog pump removal
I want to remove the smog pump according to the tech article.
One thing makes me hesitate though. Wont this affect the air/fuel mix since the oxygensensor is situated after the exhaust manifold? If I figure it right this would initially( when the pump previosly fed air to the manifold) give to much air at the carb?
Please tell me that Im wrong or that it doesnt matter since I really want to get rid of the smoggarbage.
Hasse
Sweden
Old Apr 23, 2004 | 11:17 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
The smog pump just feeds air to the CATS. The air is suppose to burn the rest of the gases inside the CATS to make it emissions legal. That's why if you have good working CAT or CATS you do not want to get rid of the pump. If you do you're looking for them to clog up. Most people do this after they gut the CATS out because the pump is not serving a purpose anymore (just blowing air into a hollow exhaust pipe).
It shouldn't effect the O2 sensor. You just cap off the AIR tubes coming out of your headers or exhaust manifolds, then all the exhaust has to go through the manifolds and out the exhaust pipes.
Old Apr 24, 2004 | 12:35 PM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
smog pump delete
I was told by someone that the smogpump pumps air into the exhaust manifold until the engine has heated up, and then into the cat. Is this then incorrect?
Old Apr 24, 2004 | 12:55 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Thats exactly how it works.
Old Apr 25, 2004 | 08:38 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
¨Then if this is how it works, the oxygensensor should get a richer reading resulting in fooling the ECM to make the air/fuel less rich?
Old Apr 25, 2004 | 10:33 AM
dankhound's Avatar
Car: 91 RS
The air pump doesnt affect the o2 at all. When the car is cold the air is pumped into the manifolds. That does change the o2 readings but it doesnt matter because the car is in open loop and the ecm is ignoring the o2. When the car goes into closed loop the air is swithed to the cat. Since that is after the o2 the o2 readings arent affected.
Old Apr 25, 2004 | 11:55 AM
HasseO's Avatar
Car: -88 TA GTA
Engine: 350 tpi
Transmission: TH700
Ok thanks for this great information. Ill get rid of the cat and the smogpump.
Old Apr 26, 2004 | 12:25 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
According to the 8D code found in 90-92 TPi cars ECM changes the O2 readings by 100mV when AIR is diverted.....
/N.
Old Apr 26, 2004 | 10:48 AM
Engine: 383 SBC
Will that 100mv difference be a big effect? I know I couldn't tell any difference after capping off the AIR tubes.
Old Apr 26, 2004 | 11:41 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
The BLM values will "probably" be affected by it when AIR is diverted, but I dont think you will notice it unless you hook up a scan tool and suddenly sees the integrator change+BLM......
/N.
Old May 7, 2004 | 08:18 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
im glad you guys are talking about this............i read the tech article and did a search but what exactly do i ned to do to remove that smog pump and the air system??????????????
Old May 11, 2004 | 11:31 PM
Engine: 383 SBC
If serpentine, which yours should be, use a breaker bar to take the belt off, take the torx bolts off the smog pump pull it out, put a new shorter sepertine belt on (might check around at auto places) I know I couldn't get the exact size listed in tech article so when I went to the next closest it was like 29 bucks! I went to a 1/4" one way forget which and it was 10 bucks cheaper go figure. After that you need to go to a hardware store buy some pipe ends (little screw on caps) cap off the AIR tubes coming from the headers or manifolds and cap off your lines coming back up from your CAT(S) I just capped them off under the hood cause I was to lazy to remove the lines and plug them. Undo your wiring for the smog pump and that's pretty much it. I might have left something out, so you should still read the tech article I wrote this whole thing in about a minute.
Old May 12, 2004 | 09:19 AM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
lol. thanks tho its some great info!!!!
Old May 12, 2004 | 10:15 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
But does the CC carb code include that as well? MAF TPI? TBI?
RazorN8
Jan 7, 2022 11:44 AM
italiano67
Dec 11, 2016 09:21 AM
backtothe80s
Sep 5, 2015 12:39 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
