New Engine Backfiring & Misfiring
Old Apr 23, 2004 | 01:23 PM
MKGTA87's Avatar
I have an '87 GTA, and I just dropped in a new 350 with a Mini-Ram intake. The engine idles great but is misfiring and backfiring through the intake. It doesnt do it everything time, but when I drive it, the throttle response is delayed. The engiine will miss and backfire, and then the car takes off.
The timing is set at 6 where TPIS recommends. I have not had the opportunity to hook up a computer to the car yet. Im guessing it is some type of ignition problem. I have a new MSD distributor and 6AL box. Also new plugs, wires, and coil.
Any info or help please let me know before I have to take it to be tuned and diagnosed.
Old Apr 23, 2004 | 07:37 PM
1983Fbody's Avatar
Car: transam, el camino
Engine: 415
Try bringing the timing back a bit only take a second and move it back if it doesnt help.
Old Apr 24, 2004 | 12:16 AM
MKGTA87's Avatar
I had the timing at 6, 4, 5, and 6 again. Which direction should I try to go from 6?
Old Apr 21, 2005 | 03:44 PM
fbody83's Avatar
Car: 1983 firebird S/E
Engine: Built 350
running too lean? Valve lash? Or is this all done for you before the motor is sent out?
Old Apr 21, 2005 | 05:08 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i know it sounds dumb, but check and recheck firing order. sometimes it's the dumb little things that get us...
Old Apr 21, 2005 | 06:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd suggest leaving the timing alone; and hook up the computer; and add more fuel. Sounds like classic "lean bog".
Red iroc-z 305
Sep 30, 2015 05:22 PM
mdtoren
Aug 23, 2015 12:52 PM
db057
Aug 22, 2015 08:17 PM
mdtoren
Aug 16, 2015 05:45 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
