changing alternator, How?
Old Mar 11, 2001 | 04:38 PM
ryansell's Avatar
I posted the other day about how to change my alternator. So i went out today and bought the hex wrenches only to find that the bolts won't budge. These wrenches are very small, I don't think I can get enough leverage with them. Do you guys use a special type of hex wrench to get at that one bolt? There is another bolt in there that I thought was hex but on closer inspection I'm sure it is not. It's on the right side, looks almost rubber or plastic and has a very strange pattern. I'm about to shell out another $100 and have someone else do it. Has anyone else had trouble changing out this blasted thing?
-1990 Firebird Formula, 5.0LTPI
Old Mar 11, 2001 | 04:44 PM
JETHROIROC's Avatar
I think they are Torx bolts, but I haven't looked in awhile, so the easiest way to get them is to buy a set of Torx bit sockets for a 3/8" drive ratchet, then you can use a long handled ratchet if you need more leverage. If they have a star-type pattern it is definitely Torx. Hope this helps.
Old Mar 11, 2001 | 04:52 PM
AustinT's Avatar
t50 torx
Old Mar 11, 2001 | 05:59 PM
ryansell's Avatar
Thanks guys.
Old Mar 11, 2001 | 06:54 PM
Andy89RS's Avatar
I don't know if mine was just an oddball, but the bolts were different sizes. I'm not sure anymore what exactly, but it was like one was a T45, the otehr a T50.
Old Mar 12, 2001 | 03:58 AM
Omar's Avatar
Mine are also like a T-45 and a T-50.
1989 IROC-Z 5.7L
Old Mar 12, 2001 | 12:07 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
They're torx..? Maybe the earlier thirdgens were different. I replaced the alternator on my 86 IROC this weekend, and it has regular bolts. Takes about 5-10 minutes to replace..
Ken
Bright red 86 Iroc-Z Choo Choo Customs Convertible
A few free mods
ChevyKen's Camaros
Administrator @ ChevyWorld.net (Now in a BRAND NEW Design)
Old Mar 12, 2001 | 12:37 PM
leirch's Avatar
The serpentine system has the torx. The v-belt doesn't. Atleast that is the only difference that i'm seeing with the different peoples rides.
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
eightsixseven
Dec 16, 2024 01:50 PM
Cornholio7979
Sep 20, 2018 02:31 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Cleotiz
Aug 23, 2015 12:07 PM
