cruise control
Old Apr 25, 2004 | 03:55 PM
ThraxXx's Avatar
Car: 1988 Pontiac Trans Am
Engine: 5.0L Fuel Injection
Transmission: Automatic 4speed /w OVerdrive
cruise control
Well I just found out my car has cruise control (yay for me) however I have never driven a car with cruise before. The cruise control controls are located on my signal light lever. There is a button on top of the lever and a switch on the side. The swich will lock if I push it to the left and will make a momentary contact if I push it to the right. The button is also a momentary contact mechanism.
Can someone explain to me how cruise works. The haynes manual failed to cover that section. Thanks
Old Apr 25, 2004 | 03:59 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
when you first push the switch to the right, this turns the cruise on. accelerate to the speed you want to cruise at. when at that speed, press the button on the end of the lever. the car will not cruise at the speed. if you want to increase your cruise speed, puch the switch to the right and holf it there. the car will start to accelerate. when you reach the speed you want to cruise at, let go of the switch.
this is the same cruise control controls that GM uses now.
Old Apr 25, 2004 | 04:15 PM
ThraxXx's Avatar
Great thanks for the info. Greatly apreciated.
Old Apr 25, 2004 | 07:54 PM
curt86iroc's Avatar
Car: 1990 IROC
badger badger
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
scottmoyer
Sep 7, 2015 07:06 PM
