How to tell rod size? 5.7 or 5.565?
Old Mar 12, 2001 | 02:13 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Transmission: Built 700R4
I have a 400sb and I am need of different pistons. How can one tell whether the rod is a 5.7 or the stock 5.565? The engine is assembled. What part of the rod do you take the measurement from. I believe it is center to center. Thanks,
  • 412ci/sb
My Homepage
Old Mar 12, 2001 | 03:00 PM
The ODB's Avatar
yes it's center to center but good luck measuring them with it assembled.
best bet is to get the part# off the piston and call the piston manufacturer to find out.
Old Mar 12, 2001 | 03:36 PM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
Where are the p #'s normally located?
Old Mar 12, 2001 | 05:08 PM
Polecat's Avatar
on top of the piston.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Mar 13, 2001 | 07:46 AM
Josh91Bird's Avatar
Car: 1991 Firebird
Engine: 412ci/sb
There are no identifying marks on top of the piston. Is there any kind of marking on the rod itself? I have looked but see nothing.
  • 412ci/sb
My Homepage
Linson
Sep 21, 2015 01:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
