car stalled now wont start.
Old Apr 26, 2004 | 08:06 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Hey guys i got a firebird (actually different car but NEED HELP PLZ)and it stalled while driving at around 40mph. It was hesitating while at steady light gas. Now it wont start. makes sound like its gonna but wont turn. Ive been driving quiet a bit and may be low on gas. Someone that looked at it said that gas was feeding through the carb, and smoke was coming from the exhaust like when it first starts after i pressed the pedal and tried to start it. I tried jumping it using a portable starter and nothing. I was thinking it could be plugs but plugs wouldnt cause it to stall would it. What about timing or the timing chain? maybe that? I need some help fast! If it doesnt start up with a jump and some gas im gonna have it towed. pull a few plugs this week sometime and if its not that either take it to a shop or replace the timing chain myself.
Old Apr 26, 2004 | 08:11 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
good firsts steps would be the usual, verify that you have a good hot spark, air is getting in, you have compression, and timing is on.
Old Apr 26, 2004 | 08:29 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
well if it doesnt start up with a jump and some gas im gonna have it towed and check the plugs. Then if not check a few more things. If it still doesnt start either try to do the chain with my friends dad or have a shop do it.
Nate
Old Apr 26, 2004 | 10:40 AM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
try replacing the electronic control module in the distributor.
Old Apr 30, 2004 | 06:42 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
found out the problem it was the ignitoin coil. The people at autozone are so dumb though. They were getting a reading from the old one but it was coming from their fingers. LOL
nate
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
86Base
Aug 8, 2015 01:34 PM
