What should I pay to rebuild an performance engine?
Old Mar 13, 2001 | 11:53 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Any general ideas on what it would cost to have the rings and bearings replaced and a general rebuild of a 383 stroker?
It was run on a lot of boost(15lbs). But it was on forged pistons so hopefully it held up. I still think a rebuild is a good idea before I put it in anything.
[This message has been edited by Aaron91RS (edited March 14, 2001).]
Old Mar 14, 2001 | 07:57 AM
b9radz's Avatar
The least money will be spent on parts if your sourcing out all the labor. Are you pulling the motor yourself,or driving the car to a shop and telling them to rebuild it? You'll save alot of money if you do the R&R of the motor yourself.
Parts cost: $85-130rings,50-60bearings,20oil pump,90-110gaskets.
Labor: Clean block,install cam bearings and hone-$75-125. To do the rebuild,if you deliver the motor probably around$400-700.If the shop is going to R&R the motor add another $300-500.
Good Luck.
My sons car: 86 Iroc,388ci,Brodix,Victor jr,TPI-700r4,3:73.
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
