fuel pressure regulators
Old Mar 14, 2001 | 03:26 PM
v6-3.1's Avatar
what are the benefits of an aftermarket fuel pressure regulator????
Old Mar 14, 2001 | 03:29 PM
Mike89GTA's Avatar
You can turn up the fuel pressure to get more fuel.. only downside is that you lose MPG.
Old Mar 14, 2001 | 05:07 PM
mostafa3k's Avatar
To my knowledge that's not completely true mike. With higher pressure the fuel atomizes better, and any chemist knows with more surface area, you get better reactions on any chemical.
With WOT that may be true, but regular driving wouldn't be the case, and if you're lean you may get even better milage. Considering that you will burn up more fuel.
....unless i'm completely wrong.
Old Mar 14, 2001 | 06:10 PM
Mike89GTA's Avatar
You may be right.. all that I know is my fuel mileage seemed to go down when I had the AFPR put on. Maybe it's because I was flooring it more often
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
