engine sucked in water need help....
Old Mar 14, 2001 | 08:51 PM
illegalz28's Avatar
my 91z28 was in a fresh water flood and the engine has water in it. i drained the oil today and water cam out for a second. i then pulled the number 1 plug and water came out of the head. what do i need to do to get this thing running again? i am puilling all plugs tomorrow and will attempt to pop start it to see if the engine rotates at least. if it does thats good. but what else should i do. the water got up to the plenum. the rest of car is ok luckily just some minor cleaning and elctrical stuff and new parts and new everything.
Old Mar 14, 2001 | 09:14 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Drain oil, refill. Change filter.
Pull all plugs and crank with plugs out to get all water out.
Re-install new plugs and try to start.
After it starts, run for a couple of minutes, change oil again.
The key is to get the water out of the engine as soon as possible. It will do bearing and cylinder wall damage.
We were out wheeling one day and sunk a toyota 4wd in a river, it stalled and we got it winched to the shore.
We cranked it over and it fired right up after it cleared the engine. Not the best thing to do but it worked.
Was it running when it injested wa-wa??
If so, you might have some issues with crank to piston clearances......
Now as far as the computer and other electrical items...thats another post in a couple of months.
Edit: Don't forget to check all other fluids too (rear end, trans,etc.) These all have vents that will let water in.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
[This message has been edited by Engineboy (edited March 14, 2001).]
Old Mar 14, 2001 | 09:17 PM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Engineboy:
</font>
...Not to mention cracked castings...
illegalz28's Avatar
the engine was not running at the time of the flood but this happened in october. i just now got the car home. I am building a 350 but would realy like ot get 305 running and have car mobile.
Old Mar 14, 2001 | 09:20 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
If this happened in Oct. and you are just now getting the water out, you may be too late.
Rings + rusted cylinder walls + water sitting in crankcase = VooDoo
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
Old Mar 14, 2001 | 09:24 PM
illegalz28's Avatar
well, it i can loose nothing if i try and pop start it. at least i will know what the engine is thinking after i do it tomorrow. it will either rotate and cough a few times or play frozen eskimo forever. we will see, i will let you all know tomorrow.
Old Mar 14, 2001 | 09:36 PM
82camaro's Avatar
Car: 82 camaro SC
wd-40/pb-blaster or some other rust buster down the cylinders to break the rust free. If it's cold enough where you are the rust might not be that bad.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
toronto formula
Nov 10, 2015 06:17 AM
lakeffect2
Aug 23, 2015 08:44 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
