How are my oil clearances?
Old Apr 29, 2004 | 10:06 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
350, .030 over, 2bolt, balanced turned 10/10:
Mains:
1---.0015
2---.00125
3---.0015
4---.00125
5---.002
Rods:
00145-.0018
Checked with a plastigage
Looks like the rods might be a little tight?! If so what do I do about it?
Old Apr 30, 2004 | 02:31 AM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
I've often wondered what you are supposed to do if your clearances are off.. I mean if they are off, you probably already own all the bearings and stuff, or else you wouldn't know they are off. If you're putting everything back together, I take it everything has been machined, so what are you supposed to do now that the clearances are off? Anyone? Would that mean it's time to go back to the machine shop?
Old Apr 30, 2004 | 05:25 AM
ede's Avatar
ede
i wouldn't put a lot of faith in plastigage but you're clearances look ok. if they're off you can swap bearing shells around. as long as the cranks is standard you can buy +.001 and -.001 bearing sets to let you open or tighten the clearance a little.
Old Apr 30, 2004 | 10:04 AM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Mine were similar to that, and I'm running fine, and oil pressure is good at 30 psi hot at idle.
Old Apr 30, 2004 | 11:48 AM
Rock and Roll~!
Hotrodboba400
Dec 10, 2019 07:07 PM
tyeo098
Nov 30, 2015 06:27 PM
CatmanFS
Sep 19, 2015 09:00 AM
timonator
Sep 13, 2015 11:49 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
