What wire do I disconect when advancing the timing?
Old Mar 15, 2001 | 01:31 PM
chris1roc's Avatar
What wire do I disconect when advancing the timing? I only have two plugs going to the distributor. One with 4 wires. Another with two, white and pink wires. I thought that that was the one but the car wouln't start when I disconected it. One other thing how far do you think that I should advance to?
88 iroc
LB9 305 tpi
k, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 15, 2001 | 01:34 PM
Steve89GTA's Avatar
The brown wire near your blower motor.
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
Old Mar 15, 2001 | 01:40 PM
chris1roc's Avatar
What blower motor?
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 15, 2001 | 01:46 PM
Dan87IROC-Z's Avatar
In the very back corner of the passenger side of your engine compartment, right about the AC and Heater blower boxes. Its a wire that breaks out of the wiring harness its a light brown color with a black stripe, I THINK. Its just a single connection. If you still don't know, ask somebody send you a picture.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
7.5" 10 Bolt with 3.42s soon to come!
Old Mar 15, 2001 | 02:02 PM
chris1roc's Avatar
I can't figure out where it is could someone send me a pic. Thanks for your help so far.
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 15, 2001 | 02:12 PM
chris1roc's Avatar
ok I found it
tnrednneck
Aug 13, 2015 08:57 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
marcusaw
Aug 10, 2015 08:13 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
