Car pinging/knocks during acceleration..
Old Apr 30, 2004 | 08:05 AM
NOCANDO's Avatar
Hi guys....
Just recently I changed my thermostat to 160 degrees. Found out my car didnt run well with it. I changed back to 180 degrees and the car runs great; however I recently noticed that it knocks during acceleration. I have my timing set at 6 degrees TDC and had been running it for a while now without problems until changing my thermostat from 160 and back to 180. Should I just run it for awhile to get the computer to learn the 180 again? or should I retard it back to 4 degrees? I never had a problem with 180 with 6 degrees TDC until I changed to 160.
Old Apr 30, 2004 | 09:11 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
I would take it back 2* and see if that helps any.
Is the car consuming oil any? Blowing smoke at startup b/c of valve seals or anything? If so the oil would cause knock at startup and acceleration...
Old Apr 30, 2004 | 10:27 AM
NOCANDO's Avatar
Thanks Chris....I ll try that. My engine has mileage on it and maybe is consuming oil. Hope to get a crate in the near future.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
