Idle and dies
Old Apr 30, 2004 | 07:43 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Idle and dies
Whats up hey I just got a tune job on my car and i replaced my IAC cuz it was idling rough. Maybe i need to tighten or loosen my IAC that could be the problem. It idles below 500 RPM's and dies. Could it be the EGR Valve or a bad solonoid. Trickster said it might be my MAP sensor.
Old Apr 30, 2004 | 09:57 PM
Vader's Avatar
Get out your vacuum gauge and meter and check the MAP if you think that's the problem:
I'd suggest checking the idle RPM and setting the minimum air position of the throttle. It might be a good idea to clean the throttle body and IAC air passages before you start adjusting.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
