Question about my starter
Old May 3, 2004 | 09:34 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Alright, bout ready to put the 355 in. Should be in the next month or so. Question I have is about the starter in the car now. Going from the 9.3:1 305 to a 10.25:1 355 plus adding Hooker LTs, is that starter gonna crap out fast u think? Would I be better off just going ahead and getting a higher torque mini-starter to help w/ the headers and so I am not up under the car changing the starting in 2 months or stranded somewhere?
Car has 120,000 miles on it, and I bet its the original... Might not be, but I have only had the car since 91,000.
Old May 3, 2004 | 09:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think you'd be better off doing that; the GN starter is notoriously weak to begin with.
I have the CVR mini-starter, which uses a Nippodenso motor, works fine on a fairly high-compression 400. Other people report that they also get good results with one of the minis that uses the other motor, which is the Hitachi; and the LT1 starter.
Old May 3, 2004 | 09:50 AM
dd85T/A's Avatar
Car: 85 T/A
Forget the stock starter. Get the high torque mini. I tried using the stock starter when my 350 with headers went in and once it got hot it would not start. I first tried a remote solenoid and a heat wrap around the starter and headers. Nothing worked until I installed a mini starter.
Old May 3, 2004 | 10:47 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
My china ministarter (powermaster) was super cheap and has served me well for 2 years with quite a bit of abuse. The starter is half the weight, has much more torque (stock would not even turn over my motor), gives more room for headers and wiring, and it looks and sounds great.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
Cleotiz
Aug 22, 2015 01:54 PM
redmaroz
Aug 16, 2015 11:40 PM
milk
Aug 10, 2015 06:26 PM
