How many of you use your SFC's as jack points?
Just wondering, I'm thinking of getting some Alstons and wandering if they are safe to use as jack points.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March alt. pulley, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5400rpm limit),Holley 9mm wires,Ac delco R43ts plugs,stock chip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
I use my SSM SFC's as jack points all the time. Mine run from front to rear along the rocker panel, and are fully welded in, so they're obviously the best place to jack the car up at.
As far as Alston's, they're tubular, and not welded completely as they run from one connection point to another....right?
Jacking up on the tube portion would scare me, and I would think they might get tweaked out a liiiiittle bit there. But near the ends would be fine I would think.
How thick is the tube walls of the Alstons??....If it's substantial, there might not be a problem, but it would still scare me jacking too far toward the middle of the tubes....Lots of bending leverage force towards the middle of the tubes.
86 Trans Am WS6 Black with tinted windows, shaved door handles
ZZ4, Mini-ram, true duals
***Too many other mods to mention***
"In the future, cities will become deserts,
roads will become battlefields, and the hope of mankind
will appear as a stranger" The Road Warrior
i use mine for a jack point and a place for jack stands.
ICON Motorsports
1st & 3rd
ICON Motorsports
1st & 3rd
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
roysatikas
Sep 22, 2015 08:15 PM
