CRAZY!!! Check this out!!
Old Mar 16, 2001 | 02:05 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
Ok now I know this sounds weird but tonight when I was changing plugs and so on.. I was pluging back in my "stock" oil press sender ((cause I put a aftermarket one in the cab on the pillar)) and the keys were not in it the fuel pump kicked on and started pumping !!!! What the he!! ???
I've had both of them hooked up for a long time and I unpulged it a while back on accident and never got around to pluging it back in
it will only run if I pluge it in and stop when I pull it out???
whats up with that??
Old Mar 16, 2001 | 02:06 PM
85berlinetta's Avatar
The fuel pump works off the oil pressure sensor. If low pressure is sensed, then the fuel pump will turn off. (This is how I heard it works). Try dixconnecting your battery then hooking the sensor up and see what happens.
Livin the hot rod dream, one day at a time.
lg4
slp muffler
pro flow air cleaner
performer intake
more to come
Old Mar 16, 2001 | 08:29 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Hmmmmm
I don't understand how there could be any relation to the oil pressure
can anyone comfirm that?? or why?
Old Mar 16, 2001 | 08:39 PM
The ODB's Avatar
yes, that is a factory safety 'feature'
shuts your fuel off in case of oil pump failure...saves GM in engine replacement costs.
Old Mar 16, 2001 | 08:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a safety feature, such that if you're in a wreck or something and the engine stops running, the fuel pump will shut off even if the key is still on.
ICON Motorsports
Old Mar 16, 2001 | 08:53 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
so what do you think that means when the car was off and it kicked the fuel pump ON
Is that right for it to do that??
In order to save the motor when the oil stops pumping and the extra fuel like cools it down or what? I dont understand cause it comes ON when there's no oil pressure
I'll disconect the battery and then plug it in...
thanks guys
[This message has been edited by Hecubus (edited March 16, 2001).]
Old Mar 16, 2001 | 09:44 PM
fordcrusher's Avatar
When I changed my engine it did this same exact thing. there was a relay of sorts to the fuel pump (been a couple years, cloudy on details) and it was fried. 12 bucks or so and I was back on the road again. My pump ran for 9 hours before I noticed and didn't hurt anything.
Old Mar 16, 2001 | 11:02 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
has this happened to anyone else??
Is the Relay bad for shure or will pluging it back in when the bat is disconected work??
any thoughts??
Old Mar 16, 2001 | 11:06 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
The fuel pump will turn on when oil pressure is sensed. Sounds like your relay is bad.
'89 Formula 383 TPI
Old Mar 17, 2001 | 12:52 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Dose anyone by chance know wich relay this is and where.. so that I can replace it??
Old Mar 17, 2001 | 10:25 PM
Vader's Avatar
Hecu,
If it's a Pontiac body:
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
[This message has been edited by Vader (edited March 17, 2001).]
Old Mar 17, 2001 | 11:02 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Vader
Sorry I really need to make a sig whith make and model in it..
It's a 91-Z 305 Tpi
In the place where you have pointed out on mine it just 2 big relays
what do you think?/
THANKS
Hecubus
http://www.tweak3d.net/temp/z28.jpg
Old Mar 17, 2001 | 11:21 PM
Vader's Avatar
Hec,
The relay yoou are looking for should have a black/white stripe, orange, dark green, tan/white, and blue or green wire in the last connector.
I'm not sure what the other relay would be on a S-D Camaro.
Later,
Vader
Nick McCardle
Sep 10, 2015 08:36 PM
383cam
Sep 9, 2015 06:01 AM
tgp1990
Sep 4, 2015 06:24 AM
86iroczwv
Sep 3, 2015 06:21 PM
z28guy134
Sep 1, 2015 11:50 PM
