Beginner Chip
Old May 5, 2004 | 08:33 AM
I_ROC U_ROC's Avatar
Car: 90 Iroc
Engine: 5.7 TPI
Beginner Chip
One of the first things I did when I got my 95 stang was buy a hypertech chip. this was one of the biggest mistakes I made with the car, I don't want to repeat it with my Iroc. Its a 5.7 tpi, auto, and I would like a chip for several reasons, not the least of which is to improve the shift points. The car has only a new tune up and k&n's but you have to start somewhere. Where do you guys get your chips from? I have learned from past experience these boards are the best product testimoniy. thanks
Old May 5, 2004 | 08:38 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Getting a chip wont change your shift points at all. Its not electronically controlled. If you want firmer shifts get a shift kit.
Old May 5, 2004 | 10:39 AM
Car: 90 Iroc
Engine: 5.7 TPI
Thanks, its only in newer cars I found out.
Old May 6, 2004 | 06:53 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
you shouldn't really need a chip for anything in a bone stock application.. start off with replacing the factory exhaust manifolds with headers and a new exhaust system the whole way back, its the single biggest restriction in these cars. To adjust your shift points (within reason) you do have some adjustability in your TV cable.. it won't increase firmness but can change the RPM at which shifts take place, keep in mind you don't really wanna go much higher then stock if any on a TPI car as the runner design limits flow at higher RPMs...
Old May 6, 2004 | 08:42 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Beginner Chip
With these cars, all the tuning (chips) are DIY since jsut about all the information for the popular ECMs used in f-bodies is openly available. All the off the shelf stuff is pretty much useless since its really not tuned to your motor, just what someone decides to throw in there. The stock chip should be fine as long as you dont make any serious modifications.
As for the TV cable, the best way to have it adjusted is to have maximum cable tension allowed by the ratcheting mechanism at WOT. This is how its supposed to be adjusted. This way the trans has the proper line pressures. The trans is pretty sensitive to how the TV is set and if its misadjusted it can cause poor shifting and damage the transmission.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
