Windshield Washers Dont Work
Old May 5, 2004 | 03:03 PM
GangsteressRide's Avatar
Car: 1987 Camaro Z28
Engine: 5.0, 305, V8, 4BBL
The Windshield washers do not work. I replaced the pump with a brand new one. The lines are clear, and the switch works. When I turn the switch the pump makes a buzzing sound, but no fluid is pulled through. It's a simple and stupid problem, and I cant figure it out. Any Imput?
87 Camaro Z28
Old May 5, 2004 | 10:46 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Got fluid?
Unless the pump is running backwards, or a line is cracked and sucking air, you have a blockage somewhere.
Old May 7, 2004 | 12:09 PM
Oddball's Avatar
Car: '86 IROC-Z
Engine: LG4 305-4BBL
Mine had the same problem until I "primed" it by blowing into the filler tube until windshield cleaner came out of the exhausts. This fixed the problem.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
TheExaminer
Aug 26, 2015 04:59 PM
