400sbc
Old Mar 17, 2001 | 08:35 PM
scott87conv's Avatar
400sbc
Did any of the 400sbc have emission control systems? I am swapping a 305 4brl for a 400 and need advise??????
Old Mar 17, 2001 | 11:29 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Yes there was smog on the 400s, why do you ask??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 18, 2001 | 12:06 AM
burnoutrpm's Avatar
switching from a 305 to a 400??? my advice?? HOLD ON!!!!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 18, 2001 | 12:50 AM
Well someone said i have a computer and i thought my car didnt have one.They said it is connected to the carb and controls the fuel and air flow. Is it possible to bypas it?
Old Mar 18, 2001 | 11:12 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Yes, you have a computer. (if the 87 in your sig is the year of the car.)
It depends on what you need to do if you have to comply with any smog regulations on what you can do to the engine.
A 400 is a good swap but you will want to open up the ex. system to help it breathe.
I'm not sure on how good the stock computer controlled carb will feed the 400, it would probably be fine, but to get the most out of your 400, you will want to open that up some to. (I can't remember if the center intake bolt angle was different in 87??...anybody??)
You will have a few headaches, for starters, the dip stick is on the drivers side on a 400. This will interfere with the dr. side ex. manifold. You will need to run headers.
This will also help cure another ex. problem with the 400s, they aren't set up for 305 ex. manifolds. The 400 heads only have 6 ex. bolt holes. The 305s use a seventh hole on the pass. side. But as stated, headers will cure this.
You can get a set of aftermarket heads that will work great,(the stock 400 ones suck), just remember to drill the extra coolant holes in them.
Now, if you don't have to smog it, its real easy, just go get a "one wire" HEI dist. and get yourself a nice performer intake, holley or edelbrock carb, (or whatever you choose) and a set of headers. Now you are rid of the computer comtrolling the spark and fuel mixture.
This has been done a ton of times on this board, there are a lot of people that can help you with this one.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
[This message has been edited by Engineboy (edited March 18, 2001).]
Old Mar 18, 2001 | 12:30 PM
Thanks for your help,the year of the car is 87.
Old Mar 18, 2001 | 04:24 PM
86SCBNJ's Avatar
don't forget the one piece rear main seal, an 87 will have a one peice rear main seal. 400 blocks have 2 piece rear main seals...
86 SC, 305 LG4, TH700R4, SLP headers, 3" cat and exhaust. Mild cam 204/214, .423/.442. SLP shift kit, richmond 3.73's w/limited slip. Susension Technique Sway Bars, Globel West Wonderbar, Poly everything bushings, Metco LCA's, Lakewood Panhad Rod. 16" ROH, with Toyo 245's. For autocross, 16" IROC's w/bfg R1's... Need more speed.....
Old Mar 18, 2001 | 05:05 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Good point, you will need a different starter and flexplate.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
evilstuie
Jan 9, 2020 08:29 PM
88TPIZ
Dec 23, 2005 03:07 PM
1986CamaroSC
Feb 23, 2004 01:44 PM
scott87conv
Mar 13, 2001 04:17 PM
Dan84SC
Oct 13, 2000 01:00 AM
