Anyone have wiring diagrams for '88 firebird?
Old May 6, 2004 | 09:21 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
Does anyone have or know how to obtain wiring diagrams for a 1988 firebird? I need to figure out how to bypass the oil press switch so my fuel pump will run only when the engine is running. I know that if I bypass the switch at the switch itself, the fuel pump will run continuously, even while the car is off. The same with my fan. I need to hardwire them both so they only come on when the car is running
Old May 6, 2004 | 11:45 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Why do you want to bypass the pressure switch? Thats a very handy safety feature.
Old May 7, 2004 | 01:56 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With that switch there, the fuel pump should come on when the motor is cranking/running. IIRC it closes at a relatively low pressure so if you have an engine that has decent oil pressure it should be able to close the switch when you crank it.
Old May 7, 2004 | 02:06 AM
Car: 88 Camaro SC
Engine: SFI'd 350
If you can post the exact specs of your car (tbi/tpi, etc) someone can probably come along and post the diag. Theyre also available in the later addition chiltons manuals.
1992 Trans Am
May 10, 2023 07:19 PM
89GTAOz
May 16, 2020 09:31 AM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Caspar
Jun 19, 2016 11:19 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
