harmonic balancer?
Old May 7, 2004 | 02:10 AM
berlinetta85383's Avatar
Car: 85 berlinetta
Engine: 383 stroker
harmonic balancer?
I was wondering if anyone could give me the proper measuerment from block face to the back side of the harmonic balancer. I'm starting to wonder weather it's fully seated against the crank, this may be part of my belt throwing issue. I know the bolt is friggin tight!! but maybe it still isn't seated all the way. Ohh ya I have a late model 1 piece main block and a scat cast 383 cank, if that would have anything to do with the proper measurments....?
Old May 7, 2004 | 05:44 AM
ede's Avatar
ede
checked what i have in the garage
402 = .750"
327 = 1.250"
90* v6 = 1.250"
all front the front of the timinf cover to the rear of the dampner
Old May 8, 2004 | 04:39 PM
Car: 85 berlinetta
Engine: 383 stroker
thanks alot, I suspect mine would be the same distance as the v6's since I believe there the same block - 2 cylinders. I will go measure it up.
Old May 8, 2004 | 04:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What design damper are you using? Factory style with the inertia ring pressed between the balancer and the hub? or the more solid 'fluidamper' design?
Old Jun 11, 2004 | 05:47 PM
Car: 85 berlinetta
Engine: 383 stroker
it was just a stock dampner, I got the problem fixed now. It was actually seated the whole way.
3GZJerry
LSX and LTX Parts
Oct 14, 2015 05:17 PM
monte87cortez
Sep 26, 2015 08:10 PM
roysatikas
Sep 22, 2015 08:15 PM
italiano67
Sep 22, 2015 08:42 AM
Magman
Sep 13, 2015 12:14 AM
