Starter Problem and Question
Old May 7, 2004 | 07:51 AM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
I only take my car out twice a week for a drive. It usually takes two or three goes to get it started. Lately, it will crank okay the first time then the second time all I hear is a click which I guess is from the solenoid and that's it, it won't turn. If I leave it a few seconds and try again it will turn. This is getting worse, Yesterday it done it three times in a row. I presum that that there is something wrong inside the starter itself. Is there rebuild kits that can be got for these starters?.
Old May 7, 2004 | 07:55 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Easier and not too expensive just to buy a rebuilt starter.
Although I see you are in Ireland...might not be so easy , HUH.
Old May 7, 2004 | 10:12 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Before you go and spread out the money, check your battery connections and make sure they are tight and clean! Just a little corrosion on the cables going into the connectors and the connectors to the posts can cause a short to ground under current draw while starting. Especialy with universal battery cable connectors. Good luck!
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
