new edelbroke air cleaner wont work
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
I tried installing an edelbrock air assembly and my car stalls out every chance it gets. Doesnt wanna shift and sounds loud like a fart cannon exhaust.(but more beefier). Anyway am I suposed to hook up the hoses that went into the stock locations? 1 vacuum 1 air intake hose with heat riser thing. and the hose/tube that went into the passenger side of the air cleaner....I wanna get that edelbrock to hook up but I dont wanna be stalling every two minutes.
also I had been told I need a tps. Im gonna try to hook it up later any suggestions?
Nate
Nate
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Did you plug the vacum line that went from the carb to the stock air cleaner? the heat riser one doesnt matter. I think you may have forgot to plug the vacum line that comes off the carb. What I did was cut like an inch long worth of hose, put a screw in it and put it back on the carb.
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
