How much of an increase in lift and duration will going to 1.6 rr give me?
Car: 89 Formula T-Top
Engine: 388 MiniramII
I have .48/.48 lift and 210/220 @ .05 duration right now with 1.5 roller rockers. This is a roller cam and has 112 deg. seperation. What kinda duration and lift will I have with 1.6 rockers?
'89 Formula 383 TPI
'89 Formula 383 TPI
or .480 lift divided by 1.5, then times(X) 1.6
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
I was under the impression that changing rocker arm ratios does not affect duration, only lift. How does a 1.6 rocker give you more duration than a 1.5?
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Duration should not change at all. The only way you can play with duration is by increasing or decreasing valve lash on a solid cam.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
Car: 4
Engine: 6
Transmission: 5
The .050" duration will change very slightly, it will increase to what used to be the .047" duration. Very tiny, a degree or 2 in most cases, but still there. The steeper the cam's ramps are, the less of a change it will be.
For all practical purposes though, the increased lift is the main thing. Also: if you are changing from stock rockers as opposed to something quality, you'll be getting rid of pieces with more or less random mechanical ratios between 1.4 and 1.45 and with all sorts of flex that gives away even more lift, and putting in something stable and predictable.
ICON Motorsports
ICON Motorsports
<font face="Verdana, Arial" size="2">Originally posted by evilho7810:
Rockers do not affect duration.</font>
On an engine with the "LA" (LameAss) or "peanut" cam, this equates to an increase in effective duration of almost 4° on the intake lobes (the difference is actually 3.68°, but closer to 4° than 3°). If you plot the valve lift curve of the cam profile with standard rockers versus increased ratio rockers, you can measure the difference.
But the real cam profile duration cannot be changed by rockers alone.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Hotrodboba400
Dec 10, 2019 07:07 PM
MikkoV
Sep 9, 2015 04:25 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
