Some random engine assembly q's
Old Mar 11, 2001 | 08:30 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
Ok so I'm still working on my 383 and I've run into another typical stroker motor problem. My rods are contacting the oil pan. What's the best way to determine where the contack is in the pan?
The next question I have is about the knock sensor.....I don't know if the hole just needs to have the threads cleaned up, but the new one will only thread in like 1/3 of the way. Am I right to assume it should go in almost all the way?? If so does anyone know what size tap I need to clean the threads up with?
Ok last question for now....the knock sensor goes on the passenger side in the block, what is the hole for on the driver side in the same spot? I originally thought that was for the coolant temp sensor, but doesn't that go into one of the heads?
Riccioli Performance Motorworks
--RPM Racing--
-Currently building first ever engine. 383 with Super Ram plenum and runners, Edelbrock lower intake, Bosch 24# injectors, AFR 190 heads, MSD ignition.
-Will be installing Baer Brakes
-Will be installing full Spohn suspension in rear
-Art Carr 700R4 trans??
Attention Everyone!!! I will be changing my name on the message boards to HardcoreZ28 sometime in the near future. Just wanted to let everyone know.
Old Mar 11, 2001 | 09:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
In order:
  • Get the grossest, most garish, disgusting color of lipstick you can find; paint the rod nut corners with it; rotate, and observe.
  • ¼" pipe. Use Teflon tape, about 6 wraps of it. Do not overtighten: this makes it overly sensitive. The Teflon tape will de-sensitize it a bit.
  • A brass ¼" pipe plug. Usually the temp gauge sending unit goes in the left head, the fan switch in the right head, and the ECM's CTS in the water outlet.
ICON Motorsports
[This message has been edited by RB83L69 (edited March 11, 2001).]
Old Mar 11, 2001 | 09:16 PM
ede's Avatar
ede
vader says hot pink from wal mart is the best lip stick for this, but it's not really my best color.
ICON Motorsports
1st & 3rd
Old Mar 11, 2001 | 09:56 PM
Car: 89 IROC-Z
Engine: 383
Ok that's a good start, but is it ok that my knock senson only goes in that far or after I clean up the threads will it go in more?
I also came up with a few more questions while I was supposed to be studying for economics tonight. First, how the hell does the oil filter adapter go on? The bolts that I got from GM look almost like rocker studs. You can't screw them in from the bottom because the oil filter will never go on. How do I do this? Also, where is the oil pressure sending unit on our cars?
--RPM Racing--
Old Mar 12, 2001 | 01:14 AM
Vader's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ede:
</font>
Yeah, but that's only because I have lots of it lying around. I get a really good deal on personal beauty supplies at WalMart (c'mon Ed - you started this...)
Paul,
The oil pressure sensor for the gauge is screwed into a port on/near the filter adapter. The oil pressure switch for the fuel pump is monted near the top rear ledge of the block, near the distributor opening but behind the ledge. If your block deosn't have the port and adapter doesn't have a sensor provision (I'd be a little surprised) you could install both at the rear ledge pressure port with a 'T' fitting, but it could get crowded there.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 12, 2001 | 01:00 PM
Car: 89 IROC-Z
Engine: 383
Thanks Vader...I'm pretty sure I remember a crusty old oil pressure sensor near the filter adapter when I picked the block up last summer. Anyways does anyone have an answer about attaching the oil filter adapter??
--RPM Racing--
Old Mar 12, 2001 | 01:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your oil filter hardware sounds like the stuff for use with the factory oil cooler system... are you using that, or just the straight filter-only arrangement?
ICON Motorsports
Old Mar 12, 2001 | 05:17 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Paul,
You have the fasteners for using the factory oil cooler. Also, be sure and check the counterweights on the crank too for your interference. I had one slightly hitting the oil pan (Moroso 6qt)when I put my pan on.
[This message has been edited by 406TPI (edited March 12, 2001).]
Old Mar 13, 2001 | 01:49 PM
Car: 89 IROC-Z
Engine: 383
Hmmm.....the oil cooler question is an interesting one. Is there an oil cooler on a 305, or just a 350? Maybe this would explain why I don't understand this one, but I would think the filter adapter would still go right on the bottom of the block? If this assumption is wrong please clue me in on how this is supposed to go. Thanks.
--RPM Racing--
Old Mar 13, 2001 | 05:23 PM
406TPI's Avatar
Car: 1985 IROC-Z
Paul,
Yup, the 305's also came with oil coolers. I am not real familiar with this set-up, but I am pretty sure that the oil filter adapter still resides up against the block and the cooler would then mount to the adapter using the fasteners you have.
Old Mar 13, 2001 | 06:53 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
It's normal for the knock sensor not to screw all the way in. Pipe threads are tapered. Just snug it.
Old Mar 18, 2001 | 07:56 PM
Car: 89 IROC-Z
Engine: 383
Is it ok to snug it if it only goes in like 1/3 to 1/2 the way? For some reason this doesn't seem right.
--RPM Racing--
Old Mar 18, 2001 | 08:14 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Be careful with the knock sensor installation. It's not an issue of how far is screws in, it's the torque.
There's a specific torque setting you have to use. Has to do with the sensativity of the sensor.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Mar 19, 2001 | 06:26 PM
Car: 89 IROC-Z
Engine: 383
Thanks....I'll check for the torque spec in the Chilton's Manual and I'll also use some teflon tape on it.
--RPM Racing--
1992 Trans Am
May 10, 2023 07:19 PM
Fast355
Dec 2, 2016 06:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
