Radiator Difference, WTF?????
Old Mar 19, 2001 | 06:49 PM
88_TAOD's Avatar
Ok, heres teh thing. My radiator took a crap so i need to replace it. My friend has one from a 1985 Z28 that he let me have. I put them up to each other and I noticed that my rad, from a 1988 GTA 350 had an extra hole. The hole is up by where the cap is. I don't know why mine has that whole and his doesn't. ANy answers.
Jason
1988 Pontiac Trans Am GTA
350 tpi, Fully Stock
BEST ET 15.4
Stereo
Alpine CDA-7864
Power Acoustik Apache Series 2200 watt amp
Two MTX Thunder 8000's in Thirdgen Box
Old Mar 19, 2001 | 06:55 PM
The ODB's Avatar
it's the return hose for your heater.
just hook it somewhere else like back on the intake.
Old Mar 19, 2001 | 06:57 PM
88_TAOD's Avatar
What do you mean???, how do i do that
just cut into the hose or by pass the radiator..., It is a small hose, not a big one
Jason
BEST ET 15.4
Stereo
Alpine CDA-7864
Old Mar 19, 2001 | 07:33 PM
The ODB's Avatar
as long as it ciculates back into your cooling system, then it doesn't matter how you do it.
Old Mar 19, 2001 | 07:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It might be for a low coolent level sensor. Just plug it.
Old Mar 20, 2001 | 09:55 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
ODB is right, thats your heater return hose. The easiest place to plumb it back into your system is the same place it was on the 85. On the water pump, on top of it you should see a pipe plug. You need to remove that and put in the appropriate sized nipple for your heater hose. You can get the nipple, prolly at any hardware store, definitely in any automotive store, usually with the HELP! stuff.
...ed
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
