Engine ran, but rockers came loose. Is it possible pushrods are too long?
Old May 9, 2004 | 07:07 PM
Nightrider350's Avatar
Car: 1988 Black Firebird
Engine: Chevy 350ci
Transmission: 700 R4
I just got my newly rebuilt 350 engine running, it took 6 months. After running it for 30 min to set the cam. I drove it around the parking lot. On my second pass the nut on one of my roller rockers came off, causing the exhaust valve on one of the cylinders to stay closed. We checked a couple others and they became loose as well. Is the problem that we didn't tighten them down properly, or could the problem be that the length of the pushrods might be too long?
Old May 9, 2004 | 07:38 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
Night rider,
I had this same problem. It was the nuts for the rocker studs. I used the old ones and should have gotten new ones. They would not stay tight. Check them first. Easy and cheap fix.
Azrael91966669
25
Jun 20, 2017 04:04 AM
cstrobel65
Aug 15, 2015 10:19 AM
NufNuffZ28
Aug 14, 2015 09:12 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
