HELP!!!!! 1984 305 Intake manifold - oil press switch for gauges verses idiot lights
Old Mar 20, 2001 | 06:36 AM
Boomer's Avatar
I swapped an idiot light cluster for an analog gauge cluster - I picked up an AC oil pressure switch for gauges. It is way too large to fit next to the distributor where my origial idiot light switch was located.
Does anyone know if there is an extra special switch I need, or maybe an adapter of some sort? It seems strange that GM would have two different manifolds just to accomodate two switch sizes.
ANYONE - please help!!!!!!
thanks,
Boomer
Old Mar 20, 2001 | 08:42 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
There is a brass fitting that puts the oil sending unit out at an angle.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
My favorite quote about D.E. "He can see air"
Old Mar 20, 2001 | 11:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right... you can duplicate the thing the factory used if you go to the hardware store and get some brass pipe fittings:
1/8" pipe nipple, 2" long
1/8" pipe elbow, female both ends
ICON Motorsports
Old Mar 20, 2001 | 12:16 PM
Boomer's Avatar
Thanks guys - done! and it works great!!!! Very tight in behind there though.
b
colton_carlson
Mar 8, 2019 12:21 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
tnrednneck
Aug 13, 2015 08:57 AM
Jake_92RS
Aug 11, 2015 10:39 AM
