Headers for angle head plugs...
Old May 10, 2004 | 01:05 PM
kaylin4u's Avatar
I need to know if there are any headers made that will bolt up to my Dart Pro 1 heads and my exhisting exhaust collectors? My heads are angle plug heads.
Old May 10, 2004 | 09:30 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
TTT
Old May 11, 2004 | 12:31 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
By existing exhaust collectors, do you mean original manifold style, or an aftermarket one?
Old May 11, 2004 | 12:36 PM
kaylin4u's Avatar
Well, I just took off my manifolds, so I was hoping there was a shorty style header that would work. I noticed that most of these aftermarket headers require a adapter to make it work with your existing exhaust setup. Just wished there was a set that just replaced your standard manifolds.
Old May 11, 2004 | 01:59 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
There are no headers that will bolt to that pipe, but most shorties you buy come with a y-pipe included. Anyway, the stock pipe is pretty restrictive, youre better off replacing with something that has some flow potential.
Old May 11, 2004 | 03:21 PM
kaylin4u's Avatar
I just noticed in your profile that you're using a transgo shift kit. Can you tell me about your experience with it in your car? I might be looking into it. Also, what hp/torque are you pushing with your car? Thanks
Old May 11, 2004 | 11:18 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Ive only got about 700 miles on the engine/trans, Im still working the bugs out. So far though, the kit seems to have really firmed up the shifts, no delay or flare. I didnt do the install myself, but it took an experienced trans. tech the better part of a day. Theres a lot to it compared to most. As far as my power/torque, Im not sure yet. Im dynoing it in June at the midwest fbody meet, hopefully at least 340-350hp at the wheels.
evilstuie
Feb 28, 2016 03:33 PM
CRFred
Feb 7, 2016 11:39 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
