hydraulic lifters
Old May 11, 2004 | 08:53 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
hydraulic lifters
I was adjusting the valve lash and I noticed that some of the lifters were easier to depress than others. How long does it take for all the oil to come out of the plungers in the lifters? Is it better to set the valve lash while the lifters are still full of oil or when the plungers are empty? They are brand new lifters. Thanks.
Old May 11, 2004 | 11:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I assume you're adjusting them without the engine running.
Doesn't really matter. You only tighten them down enough to just take out the slack, so the lifter pluger is still up against the clip. Then you give them the extra turn, 1/4 - 1/2 (but all the same amount, whichever you choose).
When it is started, they will fill and pump up.
88SS6SPEED
Nov 11, 2015 07:05 AM
topteam54
Oct 6, 2015 12:21 AM
skinny z
Oct 5, 2015 06:23 PM
mfp189
Sep 27, 2015 09:25 AM
dimented24x7
Sep 6, 2015 03:51 PM
