Trans Crossmember Bolts Broke. How To Fix?
Car: 1988 Camaro
Engine: 350 V-Eight
I've read through the other posts about this, but Im not sure if anyone else has had this idea...
All 4 crossmember bolts are broken off inside the frame. Instead of drilling them out for hours, can I make a rectangular cut in the frame, around the broken bolts, weld new nuts to a new piece of metal, put it in place and weld it on? This is the only thing holding me back from getting my engine in...
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
Originally posted by 5.8L Camaro
I will do it. Whats the best tool to use to cut the frame?
i like cutting wheels....
84z96L31vortec
Aug 20, 2017 12:16 AM
91, bolt, bolts, broken, camaro, crossmember, fbody, fix, repair, snapped, thirdgen, trans, transcrossmember, transmission, z4
