What heads and cam to change to?
Old May 11, 2004 | 04:54 PM
justanothercar's Avatar
Car: 85 z28
Engine: 355
Here is my setup,
stock rods and crank,cast .100 dome pistons, all balanced. edelbrock 600cfm carb wiend intake.
Right now i have a cheap summit 465/488 cam and 882 heads
I want to go all roller and get some good heads, but iim really not shure wich heads/cam will work well together and i dont want to waste my money anyone have any suggestions? remember i need big cc heads 72+ and im not shure how much lift i can have beacuse of the dome pistons.
:lala:
Old May 12, 2004 | 12:52 AM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
check out AFR and Pro Lightning heads. Both flow well and can get large chambers. Also check out comp cams extreme energy hyd. roller cams.
Kevin
Old May 12, 2004 | 01:04 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Before any recomendations can be made, we need to establish a few things first:
What is the budget?
What is your compression as it stands with the '882' heads?
Define "full roller" setup please
Once you answer these questions, we can prescribe a few things.
Old May 12, 2004 | 07:38 AM
Car: 85 z28
Engine: 355
Budget will be about 1500-2000 for the heads,im adding roller rocckers,lifters and cam. I think my compression is about 10-1 right now. I would like to stay under 5500rpms beacuse of my stock bottom end.
84z96L31vortec
Aug 20, 2017 12:16 AM
gta90
Sep 15, 2015 04:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
