Borrowing my friends ws6 for a couple days, wow is it fast
Old Mar 19, 2001 | 09:46 PM
chris1roc's Avatar
I traded cars with my friend for a couple days. He has a ws6 trans am. Holy **** is that thing fast. It has the 6 speed. I was just wondering what engine it has? LS1? How much horsepower does it have? I have to get an engine like that for my car. It's a 97 trans am with the WS6 package. Thanks.
88 iroc
LB9 305 tpi
k&N, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 19, 2001 | 09:50 PM
FormulaKid's Avatar
Car: 1989 Firebird Formula
I think it does have the LS1...but I'm not sure. The LS1 engines easily run 13's and sometimes higher 12's stock. A very nice engine indeed.
Old Mar 19, 2001 | 10:05 PM
chris1roc's Avatar
I have major traction problems when I am driving it. I can put it in 1st punch it and I just sit there and I end up maxing out my rpms. I love it. It's great.
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 19, 2001 | 10:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Its got the LT1 LS1 came out in 98 LT1's are good for mid 13's
Old Mar 19, 2001 | 10:12 PM
chris1roc's Avatar
how much horse power?
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 19, 2001 | 10:17 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
Welp, i'm thinking it's the LS1 and they dyno around 325 - 330 (Figures taken from actual dyno results) on average. 13.3 is common stock, 12.9 is more common with K&N's, airbox lid, and a ported MAF. Although don't get me wrong, some do run 12's stock, but more common to see 13's.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
Old Mar 19, 2001 | 10:24 PM
LottaBallsCamaro's Avatar
1997 camaro LT1= 285hp@5200 325ftlb@2400
Could you stop by my house?
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Like Mkos1980 said, it has an LT1. LS1 did not appear in F-Bodies untill 98. I think the LT1 had 275 hp stock, the WS6 package added a bit with the ram air, I believe.
Old Mar 20, 2001 | 12:32 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
305HP LT1. Good for a 14.0-14.2.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Mar 20, 2001 | 12:45 PM
chris1roc's Avatar
I know that to see what engine our cars have you look inside the glove box. Does anyone know where to look for this car?
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 20, 2001 | 12:51 PM
chris1roc's Avatar
Oh another thing, I raced a z28 today. I think that it was around a 93 - 97? Not to sure it was that type of body style. but anyway I killed it. I don't know if it was because a woman was driving it though? But I killed her. hehe. I love this car.
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Old Mar 21, 2001 | 01:04 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The motor is an LT1 and 285 horses.
I drove my friends 96 T/A with the M6, 4.10 gears, headers, and a cutout.
That car blew my mind. He can smoke 1st and 2nd and chirp 3rd and 4th.
He ran a 13.42 a couple of years ago. Got a 13.67 last saturday with a 20mph head wind.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Mar 21, 2001 | 01:12 AM
Dan87IROC-Z's Avatar
From what I have read in Motor Trend, stock LS1 F-bodies will usually run somewhere in the 13.8-13.6 area. The LS1 Vettes are running low 13s stock, I have seen from 13.3 to 13.1, reguardless, they are f***ing fast!!!
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 21, 2001 | 07:31 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Just pop the hood and look at the plenum, if it's aluminum and looks pretty kewl, is a LT1
If it's black plastic and looks like hell (or it's missing a cover) it's the LS1
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 21, 2001 | 10:53 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
LT1, The 97 TA's were rated at 305hp with ram air, I think 285 standard, Kevin, LS1 began in 98
Old Mar 21, 2001 | 01:50 PM
Ovrclck350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by chris1roc:
</font>
Or you could take the simpler and easier way and look at the 8th letter of the VIN through the Windshield. I do that all the time around here when I see F-body's because I'm curious.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
chazman
Aug 28, 2018 03:25 PM
evan555222
Sep 20, 2016 02:51 AM
Thornburg
Aug 30, 2015 08:05 AM
chazman
Aug 22, 2015 02:01 PM
