Switched carb and dist. Won't start now....
Old Mar 21, 2001 | 07:43 AM
cbpldc's Avatar
Hey all,
Der Ubermechanic is at it again..... I went from an electronically controlled
carb and distributor to a Non-cc carb and dist and finally got it all put
back together. I never removed the plug wires so I'm pretty sure the firing
order didn't change. I am also sure that the carb is getting gas because
I forgot to properly tighten the fuel line and it shot gas all over the
engine compartment. There were two wires coming out of the distributor,
an orange and a black one and I connected those to where the orange and
black wire came off of the old distributor. The engine just cranks and
cranks but never fires. Any insight as to what it might be?
TIA,
Chris Payne
'92 RS
'84 S/E
Old Mar 21, 2001 | 06:36 PM
ede's Avatar
ede
stupid question, but did you put the distributor back firing on the same cylinder it was when you pulled it? i'd guess it's out of time.
ICON Motorsports
1st & 3rd
Old Mar 22, 2001 | 05:52 AM
cbpldc's Avatar
I faced the rotor the exact same way when I put the distributor back on, however, I had to rotate the body of the dist. about 60 degrees counter clockwise. I checked the firing order as well. I think that my timing is just really off as well. So when I go home tonight, I'm going to play with the timing. Anything else I should be looking at?
apo_bailon15
Mar 28, 2016 05:20 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
86IROC112
Aug 17, 2015 02:00 PM
djmarch
Aug 9, 2015 05:27 PM
