Smog System
Old Mar 20, 2001 | 09:03 PM
92rscamero's Avatar
Smog System
My car still has all the smog stuff like EGR, AIR, the smog pump basically the whole system. I want to get rid of the whole system but I wathe smog nt my car to pass test where they stick a tube up your exhaust and figure what your emissions are. Does EGR, AIR affect the emissions of my vehicle? In general, if I got rid of the whole smog system got the proper length belt and welded up the hole in my headers where the EGR was could I pass a visual inspection?
Old Mar 21, 2001 | 01:09 AM
Mike635's Avatar
Hi, Dont know about Texas,but here in Cali we have a underhood visual and a manual function plus the sniffer.So if anythings missing or not operative you probably wont pass. Mike
Old Mar 21, 2001 | 09:58 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you remove your smog equipment you wont pass a visual inspection.
C-A-M-A-R-O No "E" in it.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 21, 2001 | 11:15 PM
GTAMAN63's Avatar
92rscamaro,
Yup, if they check under the hood for smog, you're screwed. However, at my e-check (in OH) they don't look under the hood and just do the sniffer test. I left all my smog equipment off and passed the sniffer with flying colors!!! Check out this link for the actual results. https://www.thirdgen.org/messgboard/...ML/006868.html
Barry Izold
89 T/A, GTA
Modified 350/T-5
[This message has been edited by GTAMAN63 (edited March 21, 2001).]
Old Mar 22, 2001 | 11:40 AM
91RedBigFinZ's Avatar
yeah. ive seen camaro spelled camEro on several occasions.. magazines articles mostly.
'91 Z28 50,000 miles:
K&N; Fastchip; Airfoil; Custom 'Ram-Air'; SLP Headers; Slp Runners; Borla Catback 50% open; Poweraid TB spacer; March underdrive pulleys; Accel Extreme 9000 wires, coil; Hypertech rotor, cap; NGK platinum plugs; manual fan switch; TB coolant bypass; Pirelli P7000 Z245/50/R16 all season tires; Energy suspention motor mounts.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 10, 2015 09:39 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
