1.6 rocker arms
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
1.6 rocker arms
would it be ok to go with a nice new set of 1.6 rockers on my otherwise stock l03?
i would need the 3/8" stud correct?
and they should just bolt on?
how much gain would i feel for the 200 dollar sum it would cost me?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
How worn are your stock valve springs. 1.6 rr's on a LO3's have been proven to reduce et's by .2 and gain 1mph. The stock LO3 cam needs all the help it can get. For most stock cars the money could be spend elsewhere but on LO3's they work suprisingly well.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Im sure they come in either 3/8 or 7/16 stud sizes
increasing the rocker ratio is the cheap way of boosting the cams lift and duration, without actually changing the cam itself.
do a search. This has been talked about before.
*edit* yes, what about your valve springs. is there enough clearance for the added lift? amongst a few other things...
Car: '02 Z06
Engine: L33 5.7
im not sure, kinda why im asking, will they fit under my stock valve covers?
im not too familiar with rocker arms.. what all would i need to check to make sure they work?
Car: '90 RS
Engine: 377 LSX
Car: '90 RS
Engine: 377 LSX
hye thanks for looking that up man.
and what is the stock lift on these heads anyways?
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
take your lift now, example .400/1.5 = .266 take that and multiply by 1.6 and you get .426, thats the new lift.
You would have .373 intake lift, and .410 exhaust.
Car: '02 Z06
Engine: L33 5.7
cool im looking at a .458 lift
its gonna be close, but safe.
cant wait someday for new heads and cam,
with the rockers, i will have a .535 lift. is that too extreme? the heads im looking at support a .560 lift.
(this is exhaust lift, being the bigger number of the two)
Originally posted by deepstage69
Ok nevermind you said you had an 89 tbi 5 speed
your lift would be .443 intake, and .459 ex.
Car: '02 Z06
Engine: L33 5.7
ive looked at bigger cams, but they say u need a stall converter..
this is the biggest i can go i feel.
http://www.jegs.com/cgi-bin/ncommerc...96&prmenbr=361
part # 249-08-422-8
Grind: 270
Lift: .495''/.502''
RPM Range: 1600-5400
theirs the cam right under it
Lift: .510''/.520''
RPM Range: 2200-5800
but i dont kow about that rpm range.. my idle will kill me.
and the intake manifold im looking at only pulls to 5500 so that extra 300 are gonna be wasted.
part # 249-08-422-8
Grind: 270
Lift: .495''/.502''
Lift: .510''/.520''
Car: '02 Z06
Engine: L33 5.7
Originally posted by 25THRSS
All 305 tbi's got the peanut cam, which comes to .350/.385 with the stock 1.5 rockers. He would have 373/410 lift with 1.6 rr's. I've heard from numerous sources that this will be fine on stock valve springs, but I am still wanting hard facts on what they can actually take.
thats the cam with the automatic tranny, ive got the rare 5 speed which has a cam with .415/.430
Car: '02 Z06
Engine: L33 5.7
are u serious? that makes me mad. thirdgen tech data should note that.
where is this info found? so i can see it for myself.
Car: '90 RS
Engine: 377 LSX
25THRSS is correct on everything above. Although not certain, I am pretty sure the valve springs were different between the LO3 and L98. Some other points to make.
-You do not need a stall converter since you have a T5.
-You have about the smallest cam out there ever put into a small block.
-Your LO3 cam is no different than any other 305 TBI cam out there.
-There was no G92 or equivalent performace upgrade for TBI cars
Car: '02 Z06
Engine: L33 5.7
how will my idle be if i had this cam with a
Grind: 82
Lift: .510''/.520''
does rpm range mean the optimal operating range?
Grind: 82
Lift: .510''/.520''
Car: '90 RS
Engine: 377 LSX
I was going by my gm manual which lists the specs for each v8 engine that year and it lists the valves springs as being the same.
TaviZ
What is the LSA and duration on that cam? What heads were you going to use them with again? This may need to be moved into the TBI board.
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
Time to add to your tool kit.
Buy a degree wheel and a dial indicator. then instead of asking what your cam specs are, you can tell us.
A degree wheel and dial gauge are two tools you'll never have regrets about buying, you'll use them over and over again. While you're shopping, get a TDC locator too.
92rsvortec350
19
Oct 9, 2015 09:39 AM
