Got a 400 block.... and a question
Old May 14, 2004 | 03:32 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
So I got my hands on a usable 4.125" bore block, and the crank I have is a 2pc seal with 350 mains. And I'll be needing a set of main bearing spacers to make this work.
I'm just curious whether anyone who has experience with these spacers has any advice to offer, such as what brand is best, or special setup hints.
Old May 14, 2004 | 03:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
A 400 crank is about the same price and gives more cubic inches.
No special assembly tips. They're basically just 400 main bearings that have been align-bored to the 350 bearing bore diameter.
I used the Comp ones.
Old May 14, 2004 | 03:42 PM
Car: '85 IROC
Engine: LB9
Cool... thanks
The crank I have is an Eagle 3.75" w 350 mains.
Old May 14, 2004 | 03:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Ahhhh... I see
Old May 14, 2004 | 04:46 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Thats the factory 400 stroke, just so you know
Old May 14, 2004 | 05:10 PM
N8MAN1068's Avatar
Car: 85 ta ws6 KITT
Engine: Lb9
Transmission: th350
or he could destroke it and run a 377.
Old May 14, 2004 | 05:22 PM
Car: '85 IROC
Engine: LB9
I pretty much have my choice of cranks, there's one of each here, exc 3".
Most likely I'll use the 3.75" one, unless any of the de-stroker fanatics have data that convinces me I should do something else.
Old May 15, 2004 | 02:15 PM
Air_Adam's Avatar
But why? More inches = more torque = more power.... and its more inches!!
I'd take a 400 over a 377 or a 383 any day.
Old May 15, 2004 | 02:21 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Im with Air_Adam. Why destroke it if he already has the 400 stroke crankshaft?
Old May 17, 2004 | 09:45 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
and before someone says it...
pick a RPM you want to spin your 377 at.
you can do the same thing with the 400, and make more power doing it.
Old May 17, 2004 | 10:17 AM
Car: '85 IROC
Engine: LB9
My ultimate goal is a 4" stroke in a tall block w 6.25" rods.
When/if that ever happens, then I'll have an extra block, and I can try a de-stroker.
thanks anyhow
camaro71633
Sep 1, 2015 10:24 AM
downsouthboy
Aug 29, 2015 11:29 AM
lakeffect2
Aug 23, 2015 08:44 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
