Will JB weld hold up submerged in gas
Old May 14, 2004 | 04:12 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
I am trying something new(will disclose later) but I am wondering if Jb weld will hold up submerged in gasoline as in a gas tank or fuel bowl?
Old May 14, 2004 | 04:26 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
not for long!
Old May 14, 2004 | 05:21 PM
82crossfire's Avatar
Car: 1982 chevy camaro
Engine: 305cfi
Re: Will JB weld hold up submerged in gas
i know what does hold up submerged in gasoline(maybe oil, too) but kinda gotta get some sort of an idea as to what you're doing.
Old May 14, 2004 | 06:05 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
I was going to help you later but I decided to disclose this info now
"It's strong as steel and impervious to water, gasoline, chemicals, and acids"
Taken from http://www.jbweld.net/coldweld.html
Old May 14, 2004 | 08:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
JBWeld is impervious to gasoline. I've used it to seal carb bases that have lasted for decades afterwards.
Not to rain on your parade, but there's probably not much new that you can try with JBWeld that involves gas. There's only just so many parts on a car that touch gasoline.
Old May 14, 2004 | 08:17 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
I think you missed the word Submerged! I haven't seen JB or any other product even seal a hole in a gas tank for very long much less submerged in the stuff. Don't get me wrong, JB is good stuff but it has it's limitations. Not good for tank repair because it has a hard time bonding to smooth surfaces such as a fuel tank. Good for carb. base plates though, it will stop vac. leaks!
Old May 14, 2004 | 09:08 PM
Engine: 305cfi
spray on bedliner works well for gastanks.
Old May 14, 2004 | 09:29 PM
AM Racer's Avatar
JB will not hold up submerged.
A while back, I tried it on a pin hole in a tank fuel float. It held for a short term, then came apart.
Old May 14, 2004 | 09:42 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Yea I tried it on a snowblower gastank and it held for about 2 weeks....
Old May 15, 2004 | 02:10 AM
Car: 86 z28
Old May 15, 2004 | 02:11 AM
Car: 86 z28
Old May 15, 2004 | 10:13 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It works fine, you just need to get the correct JB weld, clean the sufface, mix it right then let it cure. I used it on an old Yammaha trail bike tank and its held fine for 5 years.
Old May 15, 2004 | 10:44 AM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Was it SUBMERGED? ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
SUBMERGED?
SUBMERGED?
SUBMERGED?
submerged?
submerged?
o
o
o
o
o
o
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Dialed_In
Aug 20, 2015 01:45 PM
johanlindgren
Aug 16, 2015 12:16 AM
