putting t-top roof on non t-top car
Old Mar 20, 2001 | 04:26 PM
illegalz28's Avatar
is it possible to add a t-top roof to a car that doesnt have ttops? i figure all i have to do is cut at the bottom of the A pillers and then cut out where the factory quarter panels are welded at. has anyone done this? i work at at a body shop and have access to all tools needed. i just wantt o know if there is something that wont fit before i go ahead and cut my roof off.
Old Mar 20, 2001 | 04:40 PM
dtpmike's Avatar
First off T-tops are not worth the pain. They look cool to other peopel, but they are too much of a pain taking them off and putting them on, I never use them really even though my car came with them....plus it be very expensive and time consuming to add t-tops in.
89 camaro 305 tbi, flomaster 3 chamber cat back, gutted cat, Edlebrock open element, and a 160 degree T-stat. 2 kicker comp 12"'s, polk for the rest. Phoenix gold xs2300 to subs, kicker impulse 404XI to 4 speakers, pioneer DEH- P7000R head unit, and finally a 12 disc changer. Full leather interior from www.MrMikes.com(its nice)
Old Mar 20, 2001 | 07:32 PM
rondubbs's Avatar
my car has aftermarket ttops, in 1988 350s didnt come stock with them, so the original owner got them installed , so it is possible to do.. you might try calling a dealer and asking for the company they used to install them and refer your question to them..
Old Mar 20, 2001 | 07:50 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
the t top cars have reinforced rocker panels.you will at least need subframe connectors
Old Mar 21, 2001 | 03:08 PM
88Roc350TPI's Avatar
<font face="Verdana, Arial" size="2">Originally posted by ron rizzotti:
my car has aftermarket ttops, in 1988 350s didnt come stock with them, so the original owner got them installed , so it is possible to do.. you might try calling a dealer and asking for the company they used to install them and refer your question to them..</font>
Hey Boss,
My '88 with 350TPI is sitting right out in the driveway and last time I checked it had T-tops in it, and it came that way straight from GM. '90 and newer 350's were not available with T-tops.
Old Mar 21, 2001 | 03:50 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
<font face="Verdana, Arial" size="2">Originally posted by 88Roc350TPI:
...'90 and newer 350's were not available with T-tops.</font>
I beg to differ. Officially they didn't, but a few did slip through.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Added bonus:
Wife's car is a '00 Grand Prix GTP!
Old Mar 21, 2001 | 07:01 PM
Da91Bird's Avatar
Seriously, if it means that much to you, you should trade your car for one with T-tops. The stock T-tops can be leak prone enough, I'd hate to see what kind of problems you would encounter with a different roof that you grafted on.
Old Mar 21, 2001 | 09:27 PM
illegalz28's Avatar
i have this 91 z28 that i got for change and it has mods already. i really don't want to part with it. it is my project car but if you guys think its to much then i wont bother. i have had 5 fbodys and at his is the first one with the ttops so yo usee why i want then it is somthing that has grown on me.. it use to be a friends car and he was going to junk it.
Old Mar 21, 2001 | 09:36 PM
rondubbs's Avatar
Hey Boss,
</font>
check the rpo codes, if it is then your car is real rare, BOSS.
Old Mar 22, 2001 | 02:11 AM
burnoutrpm's Avatar
<font face="Verdana, Arial" size="2">Originally posted by dtpmike:
First off T-tops are not worth the pain. They look cool to other peopel, but they are too much of a pain taking them off and putting them on, I never use them really even though my car came with them....plus it be very expensive and time consuming to add t-tops in. i agree with this guy... they are BIG pain in the *** to take off and then put back on!! i only take mine off on REALLY hot days and even then it f******* anoying!!! if i had access to all that equipment id do a convertible conversion!! automatic and looks a hell of alot better!!!
</font>
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Mar 22, 2001 | 09:10 AM
cica55's Avatar
C&C used to do the conversion , but that was back in the day. My car has it and it's done very well. I had the headliner off and they welded in think metal supports etc...
definitely stronger than stock t-top or stock hardtop (I think).
sure you can do it yourself, but the minute you roll your car over you better pray that it will hold. I wouldn't trust it.
at least get a roll bad in the car , smple 4 point rollbar that will make sure the roof won't cave in on your head in case something bad happens.
better be safe than sorry...
Old Mar 22, 2001 | 09:40 AM
Pino91Formula's Avatar
look if you wanted t-tops you could get them end of story,.. this is allways an ongoing debate ,, if you wanted them you could get them,,, and for installing t-tops in a non t-top car ,, as long as you can find some one to do it ,,, and they didnt come with any reinforcments it the frame thats a myth, convertibles only did
Old Mar 22, 2001 | 10:44 AM
82resto's Avatar
How much would something like that cost?
Jon
Old Mar 22, 2001 | 11:22 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Okie dokie...
The panel (B-pillar?) between the door window and hatchback window has a copper colored line going across it, left-to-right, a few inches from the top of the roof. This is where GM attached either a T-top roof or a normal roof. I'm not sure where the point is on the windshield pillar, but it's probably copper-colored also.
The doors: T-top equipped cars had a reinforcement done to the doors. A few inches above the regular door latch & strike plate is another latch. It's silver colored. There's one on the door, and one directly across in the doorjam.
I'm not aware of other reinforcements done to the car.
Keep in mind too that the bodies of the f-bodies twist. The T-top roof you cut off a car might be twisted "just enough" to not match up perfectly with your car's twist. You probably also have to remove the windshield when you do the switch, to avoid breaking the glass. (I'm sure it could be done, but do ya want to chance it?)
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 22, 2001 | 08:01 PM
Omar's Avatar
my car has aftermarket ttops, in 1988 350s didnt come stock with them, so the original owner got them</font>
There are thousands of 350's with t-tops from 87-89.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
colton_carlson
Mar 8, 2019 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
3rdgenparts
Aug 6, 2015 09:03 AM
