305 to 350 Interchangable Parts
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
if i plan on dropping in a 350 later on this year what parts can i go ahead and upgrade on my 305 that will give this car a little more umph but can be switched over to the 350??? like headers, maybe an ignition box (i know nothing about ignitions), anything else like that? injectors maybe.....? adj fuel pressure regulator???
Car: 4
Engine: 6
Transmission: 5
Headers if you get ones sized for a 350, which would be 1¾" primaries; AFPR; I wouldn't bother with an ignition; high-flow cat; cat-nack; not injectors
hate to jump in before RB or five7 has the chance to answer you, but basically any external part will interchange. only problem area might be heads and intakes with the new style center bolt holes. most of the things you list aren't really regulated by engine size, like the ignition box or AFPR
Car: 1991 Z28
Engine: 383
is there anyone that sells just a 3" mandrel bent i pipe? i dont think my exhaust guy can mandrel bend pipes but im not for sure.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
And by 3" mandrel bent pipe, did you mean standard 3" pipe that can be mandrel bent or 3" pipe that has been pre-bent? Either way, i know mail order places like Summit and JCWhitney carry 3" straight piping. Im sure Jegs has it as well. Any proficient exhaust shop should carry normal 3" pipe as well. Unless you meant stainless, then that might be a mail order thing. Call your local exhaust shops and ask.
Car: 1986 Pontiac trans am
Engine: L69 305 H.O.
Transmission: Norg werner T5
Re: 305 to 350 Interchangable Parts
ok i have a question i have a 86 trans am with the 305 4 barrel carb and im ordering the 350 from the 87 TA but i want to keep it as a carb will my intake fit from the 305 to the 350? if not what will i have to do?
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Wow, reviving a thread from the dead. As for your 305 to 350 swap, if your 305 and 350 heads both have the centerbolt heads, then the intake should bolt right up. If not you can oval out the two center bolt holes on each side of the intake to get it to match up. I've done it before, but the stock 4 barrel intake was basically a piece of crap best used as a boat anchor. I would use an Edelbrock Performer 2101. All of your mounts and accessories will line up just fine. The exhaust on the 305 was marginal at best, and would be better off being swapped in order to make the most power from your 350. I can't remember what headers I used when I did this swap, since it was over 10 years ago, but there are many sugestions on the exhaust forum. The only other issue that you may run into would be tuning the Quadrajet and the ignition curve, since both are partially computer controlled. Neither is impossible, very do-able, but most people aren't willing to do the extra work and just throw a different carb and a regular HEI distributor.
Car: 1982 Z28
Engine: three 350s, all casting #370010
Every part on a 350 and 305 are interchangeable except the pistons, yes that includes the rods an crankshaft, although heads with 2.02 valves will have shrouding issues. Does that mean you should interchange all the parts no, but all of the parts are interchangeable.
i have new headers for the 350 and going to rerun my exhaust but im wanting to order new carb and intake for it but that will come in time im on a budget right now
Engine: 4++,350 & 305 CIs
The OP revived a almost a 10 yr old thread!
Car: 1982 Z28
I would imagine it would be a bad idea to put a 305 crank shaft into a 350, but would it be a bad idea to put a 350 crank and rods in a 305? I would imagine it wouldn't matter especially if you are buying aftermarket.
Car: '89 Camaro
as long as the oil pan matches the block, no. some headers may interfere with the dipstick being on the other side of the block though though.
Car: 1984 Camaro Berlinetta Starship Ed.
Engine: Worn out SBC 305 5.0L V8
Axle/Gears: Stock
So I know this thread has been dead for a good while but I'm curious, are the spark plugs from a 1984 305 interchangeable with a 1994 350?
Car: 90 Formula / T-tops
Transmission: MD8
Isn't the easy answer everything but the block, pistons, crank and heads? oh, and computer. especially for a TPI car.
They're "interchangeable" in the sense that they fit. As far as "ideal" or "right" or any of that, it's a definite maybe.
If you have a 94 350 in a 84 car that originally came with a 305, best to use the spark plugs spec'ed for that motor, and not worry about ones for the motor that was originally wrapped in that sheet metal. I can assure you, spark plugs DO NOT CARE about the sheet metal wrappings, or STICKERZZZ!!!!!, or # of cup holders, or year model. They have bigger issues on their minds.
Sanjay
Aug 12, 2015 03:41 PM
305, 350, 86, 87, centerbolt, crankshafts, engine, exhaust, fit, heads, interchangable, interchangeable, motor, parts, rods
