Looking for info on an SLP cam
Old Mar 18, 2001 | 06:54 PM
Buck Mustard's Avatar
My engine was put together by the guy I bought the car from, so I am not sure of everything that he did. However, he gave me some receipts and I found the spec sheet for the cam. It is from SLP Engineering and it says:
Gross Lift: .480 / .487
Tappet Lift: 258 / 264
Duration @ .050: 206 / 212
Lobe Lift: .320 / .325
Is this a good cam for my combo? Most mods are in my sig. The heads are stock L98 heads (maybe ported, but I don't think so). It has headers and is a TPI. Has a TPIS air foil and I think he said they did some porting on the throttle body. Has 1.6 rockers on the intakes and (I think) 1.5 on the exhaust. ADS chip.
'88 GTA w/ t-tops
355 TPI, TPIS airfoil, Edelbrock headers,
Flowmaster exhaust, cold air induction,
MSD 6AL ignition, ADS chip, 1.6 rockers on intake,
BMR STB, Spohn SFCs
Stereo:
Panasonic CQ-DFX700U
Infinity 4x6, Alpine 6x9
Rockford-Fosgate Punch 400a4
80 watt Bazooka sub
Old Mar 22, 2001 | 01:14 PM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
It's their 51002 cam. Very mild, just a little more duration on the exhaust than stock. Of course with the higher lift and the 1.6 rockers, it'll run better than stock. It's fine for your mods, as would their 51006 cam.
I'm running their 51010 224/230, .502/.510 plus 1.6's on top of that. It's definately more of a higher end cam. But still pass emissions and get good highway milage.
The
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Mar 22, 2001 | 11:03 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I put this cam in my car, along with new springs, and my car went slower. There's some other guy on the board that had the same problem.
Not to mention SLP's customer service sucks. I called them up right before Xmas and got an answering machine saying that they would be closed till after newyears. Gee, glad I didn't need any technical assistance or anything. In my opinion SLP sux. I will never deal with them again, and I know I'm not the only one with this opinion. If you like that cam, you ought to consider getting it from Comp Cams, they have a roller cam with the exact same specs. I finally got my tech help from Comp Cams. SLP didn't even have a valve spring they recommended for the cam, while Comp Cams gave me not only a part number, but also height and pressure specs on the springs. But hey, that's just my personal experience with SLP.
junkcltr
Aug 2, 2019 11:12 PM
masonta
Sep 1, 2015 06:40 PM
ambainb
Aug 29, 2015 12:43 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
