what better 350 TBI long block or stock LB9 350
Old Mar 22, 2001 | 07:13 PM
illegalz28's Avatar
I need a new engine in my 91z28 and i need ot know if I should put in a 350 replacement motor from GM rated at 245 horse or get this 350TBI engie that comes in the caprice. which has more power in long block form from the dealer. i am using a slightly modified TPI setup, hotcam, and a pr. of edelbrock heads.
Old Mar 22, 2001 | 07:38 PM
leirch's Avatar
I don't think it matters too much on which block setup you go with since you have your own heads/cam/intake and whatever else already. I doubt there is too much of a difference in block strength.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Mar 23, 2001 | 02:31 AM
IROCketZ28's Avatar
Just FYI, the LB9 was the 305 cube TPI, the L98 was the 350.
'87 IROC Z28
TPI 305
5-speed
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 1600 watt stereo system
Grant wheel
MustangBeater20
Oct 29, 2022 09:20 PM
theshackle
Mar 5, 2017 06:37 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
BBSDesigns
Aug 11, 2015 07:39 PM
