Iroc wont start
Old Mar 24, 2001 | 11:42 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
Iroc wont start
My Iroc won't start. I have checked the codes, and nothing showed up. It won't crank, and I cant hear the fuel pump come on, but everything else works. I'm sure it is probably simple but it has baffled me. Any one got any ideas? It's an 89 Tpi setup all stock. Thanks in advance.
1989 IROC-Z Original 350 was swapped for a 305! Why, I'll never know.
Old Mar 24, 2001 | 11:49 AM
87firebird's Avatar
I had a problem like that. My car wouldn't start but it tried to turn over. I cleaned the spark plugs and I got it to start. I also took the gas line going into the carb off and blew air through the carb to clean any clogs. then I tried to start the car with the gas line off to see if gas was making it to the carb. Good luck
Old Mar 24, 2001 | 08:13 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Check the ECM/fuel pump fuse by the battery on the right side of the radiator. It should have 2 wires going into it with a cover on it. I don't have access to my car so I don't remember what color the wires are. Good luck
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Mar 24, 2001 | 08:41 PM
nc-iroc's Avatar
Car: 1989 Iroc-z
Thanks. It is the starter. I just replaced it with one from AutoZone. Piece of junk if you ask me.
Frozer!!!
Jan 19, 2024 04:55 PM
Derick15
Sep 17, 2016 05:28 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
mustangman65_79
Aug 11, 2015 03:17 PM
