Car Stalling???!!!???
Old Mar 25, 2001 | 11:03 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
In park the car runs fine, but when I shift to OD the car idles really rough and cuts out, in Drive it idles rough but stays running, what could be causing this.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER
EDELBROCK 600CFM CARB.
KN AIRFILTER
UNDERDRIVE PULLEY
ACCEL HEI DISTRIBUTOR
2:73 GEARS
Old Mar 25, 2001 | 11:30 AM
Vader's Avatar
Mark,
Any DTCs (error codes)?
A good starting point is always verifying the TPS voltage, throttle minimum air position, and cleaning the IAC air passages.
If the engine is idling a little higher in park, you might have a vacuum leak or sticky IAC. Check all hoses, including the PCV system. Don't overlook the brake booster.
If the TPS/throttle adjustment/IAC cleaning doesn't solve the problem, report back with results and data, like idle RPM, vacuum, fuel pressure, timing, whatever you can get.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 25, 2001 | 11:45 AM
Car: 99 Formula
Axle/Gears: 342
I fixed the problem, it's actually pretty dumb. The guy who had the car before me installed a kickdown switch, this is why I think my OD doesn't work, well when the switch is off the car will cut out in OD, but not drive, well at least that is how I remember it, now it seems the switch has to be off for the car not to cut out.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER
KN AIRFILTER
UNDERDRIVE PULLEY
2:73 GEARS
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
