whos gonna bet im right
Old May 19, 2004 | 11:39 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
Transmission: T-5 manual
i was driving my car today going through a parking lot, im going like 10 in first adn punch it while going through a puddle , well when i get out of the puddle there is this *** awful ticking/thumping/slapping/banging noise, so i pull over and check it out, well there aint nothing wrong i can see, no water in the carb or anythng, so i drive home (a couple blocks) at very low speed, jack the front end of the car up and have a friend start it, well i cant see anything but its amazingly loud noise, i look at the oil pan and every time there is a noise the pan bottom jumps a little
so who wants to bet that my 48000 mile L-69 broke a dang rod and its barely hitting the pan causing the noise
guess its a good time to go to a 350, not the way i wanted to and a littel sooner, but whatever
Old May 20, 2004 | 12:14 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
$100 on a broken rod
Old May 20, 2004 | 04:42 AM
ede's Avatar
ede
i've not seen it all, but i've never seen an engine with a broke rod continue to run, however anything is possiable
Old May 20, 2004 | 05:22 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
That would cause for a very dead cylinder....amongst a few other little issues...
Old May 20, 2004 | 03:04 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
ya it deffinatly was not running very good
and from what ive talked to people here and waht im guessing is that if it broke close to teh crank that it could keep running sorta
Old May 20, 2004 | 03:33 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i havent seen it either..
if you want to make your block holy, just rev it now.... and make a video of it.. i wanna see!
Old May 20, 2004 | 03:39 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I've also never seen an engine continue to run after its broken/thrown a rod. 99.9% of the time it'll instantly cause catastrophic damage.
I'd also suggest you fire it up and rev it to like 6000RPM and hold it there until you hear CLUNJCLCUCBCNCCKCLACNAKACBANG ...on video of course. I mean, if you're gona replace it with a 350 anyway might as well go out with a bang right?
Old May 20, 2004 | 06:38 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
why stop at 6k wont it rev to around 8500/9k in neutral? or park? i mean theres no load on the engine and yes please video tape it..
Old May 20, 2004 | 07:21 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Dont know about the rest of you but id be pissed about trashing a perfectly good low milage L69. They may not be the fastest thing in the world but its still a decent motor. Im surprised it gave up. How high did you rev it?
Old May 20, 2004 | 08:43 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Are you sure something didn't hit the pan and it bent or got dented? On my friends 305 Camaro this happened. Popped the dent out and was as good as new.
Old May 20, 2004 | 11:21 PM
irocbarry's Avatar
Car: 85 IROC
Engine: L-69 305
ay i hve a problem with blowing it up, it runs to damn good to do that, or at least it did
it was at maybe 4000 rpm when it went, its wierd cause it never mad a huge noise, but deffinatly makes noise now
i dont think that the pan is dented, looks fine from under neath
im gonna pull the pan on saturday to check it out, hopefull i find some good news
any tricks to pulling the pan that would help
if its not to bad im gonna put a new rod in it and try to sell it, theres a lot of LG4 cars in town that have been beat by me, maybe one of them will want a stronger motor who knows
92projectcamaro
Dec 8, 2015 12:25 AM
Zane Story
Oct 8, 2015 12:40 PM
91 SrS
Oct 7, 2015 04:32 PM
Vincent135
Sep 28, 2015 10:50 PM
3.8TransAM
Sep 17, 2015 02:16 PM
