305 Stroker Motor
Old May 19, 2004 | 11:58 PM
killerbeeiroc's Avatar
Car: 1988 Camaro IROC-Z
Transmission: Borg Warner T5s
305 Stroker Motor
Hey guys, just read a little while ago about the possibility of stroking a 305 to a 323 with a 400 crank. I had never heard of that before, has anyone done this and had good success?
Just curious, I'm always ready to learn
Old May 20, 2004 | 12:15 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I will move this so that the engine builders can chime in. You will find that the 335 stroker is the most common. However, its costs does not justify the power gians.
Old May 20, 2004 | 12:26 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
A 400 crank in a 305 block (bored .030) will give you a 335.
I'd advise against it though, because the 305 has bad enough breathing problems with the stock bore and stroke (3.75 x 3.48) and the longer stroke of the 400 crank would only make the problem worse. It would be very torquey down low, but it would be gutless above 3000 rpms.
Old May 20, 2004 | 02:49 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Im with the other two. If you look into it, the power versus money put into it ratio does not justify the build up. You can build a 350 and stroke that to a 383 for about the same amount and still have an engine to use in the car for a daily driver. THe 383 will out power the 335 on the same part-for-part basis any day of the week.
My vote goes to save your money and do a 383. That also leaves a functional engine in the car that allows you to run around still.
Old May 20, 2004 | 04:39 AM
ede's Avatar
ede
for the effort and cost you'll get less than if you just went to a 350
jhawkeye
May 25, 2022 06:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mhatfield 14
Oct 24, 2015 07:48 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
