cam
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
TFS-31402000
Good idle, strong low-end torque, 2,400 to 5,900 rpm powerband. Small tube headers and free-flowing induction recommended. Compression ratio: 9:1 to 10.5:1.
214 intake/220 exhaust @ .050" duration
.301 in./.310 in. Lift @ lobe
.452 in./.465 in. Lift @ 1.5 ratio
110° LSA
110° LSA
For less amount of money, you can get a hydraulic roller cam from Comp Cams that was specifically designed for TPI engines. And they have a little bit broader of a powerband.
Unless you have the cam already, in which case, it would work. Nothing is going to make the car not work. It just wont fuction very well. Some tuning would be desired as that cam appears to me as if it were designed/ground with carbureted applications in mind.
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
thanks for the help........ do you know the part number for the comp cams one? and im getting the trickflow heads so i figured it would be a good idea to get there cam too but if u know a better match let me know
Car: Z28
Engine: Sb2.2 406
Assuming this is a bone stock, the 08-501-8 (XR264HR) is a good cam. If you are planning chip upgrades and tuning, of course a larger cam can be used.
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Re: cam
Would this trick flow cam be a good choice for a carb'd L98? I've got a set of Torquer heads and Scorpion 1.6 rockers sitting around until I get a cam. $120 at summit, might be the right time to pick one up.
