RADIATOR Sensor????
Old Mar 24, 2001 | 08:55 PM
88_TAOD's Avatar
RADIATOR Sensor????
I have a problem. I am swapping a radiator from my stock 88 GTA's, to a radiator from a 85 z28. There is one hole i have on mine that isn't in the z28 rad. I was previosly told on this board what that was and now i found another difference. There is a sensor or something it is a plug with a small piece of metal sticking out that plugs into the right side in the middle on the radiator. There is not whole for that sensor/plug on the new rad. So what should I do.
1988 Pontiac Trans Am GTA
350 tpi, Fully Stock
BEST ET 15.4
Stereo
Alpine CDA-7864
Power Acoustik Apache Series 2200 watt amp
Two MTX Thunder 8000's in Thirdgen Box
Old Mar 25, 2001 | 10:51 AM
Vader's Avatar
88,
Check the archives on this. I recall a sensor in the right tank of some radiators (probably GTA) that were used as a coolant level sensor. I might be off on this, so a check of the archives would be a good idea.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 25, 2001 | 04:32 PM
88_TAOD's Avatar
Ok, so according to an older post i heard that it is for the gauges, to read the temperature of the car. Alright so I don't NEED to have it hooked up correct, it is just for my guages
Please help.
Jason
BEST ET 15.4
Stereo
Alpine CDA-7864
Bubbajones_ya
Jul 6, 2024 08:32 PM
Bohemian
Aug 15, 2017 05:11 PM
92firebirdguy
Sep 1, 2016 07:53 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
romcjr
Sep 17, 2015 05:18 PM
