Whining Engine !!...Please help
Old Mar 25, 2001 | 11:50 AM
88IrocConvertible's Avatar
A couple of days ago my car started making this annoying whining sound under the hood, it goes off after a few minutes when it is running but its still annyoing. I can't tell exactly where it is coming from, but it seems like possibly the left side (if you were standing in front of the car facing it). I have noticed no changes at all in the car. Everything works the way it used to except for that sound. I have no clue what it could be…I had my alternator changed about 2 weeks ago, also the belt….could it be possible that it has anything to do with that ? Any ideas ? I would like that annoying sound to stop. Thanks a lot,
- Alex
1988 Camaro IROC-Z Convertible
305 TPI with A4 Tran.
2:73 Gears
....Bone Stock and itīll stay that way :-)
Old Mar 25, 2001 | 12:47 PM
mtx28's Avatar
did it start immediately after you had the belt changed? also, does it change with rpm? does it only do it when you turn the wheel? also.. why you keeping it stock?
Old Mar 25, 2001 | 02:09 PM
<font face="Verdana, Arial" size="2">Originally posted by mtx28:
did it start immediately after you had the belt changed? also, does it change with rpm? does it only do it when you turn the wheel? also.. why you keeping it stock? </font>
it didnīt start immediately after I had it changed, it was about 2-3 days after it...... it stops when I hit higher rpmīs but as soon as I run idle again itīs there.....but like I said before its gone after a few minutes, never the less its annyoing....the sounds is there weather I turn the wheel or not....the reason Iīm keeping it stock is because its a rare car in good condition and if I would do mods on it it would kill the value
2:73 Gears
Old Mar 25, 2001 | 05:17 PM
Anymore ideas ????
[This message has been edited by 88IrocConvertible (edited March 26, 2001).]
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
