cant get engine to run right
Old May 20, 2004 | 08:15 PM
batchik2's Avatar
Car: '86 Z28 Chassi, '91 V8 S10
Engine: 350 bored .030 new cam, #416 heads with 1.94" intakes
Transmission: S10-NV3500 5spd
i got my car running last weekend. i was messin with the distributor and figured out that it was 180 degrees off. when it was running it was backfireing out the carb. the fireing order is right, i checked everything like 1000 times. i had to pump the gas to get it to stay at like im guessing 1000 rpms. i just took the timing cover off to make sure the dots were lined up on the chain gears and they were. now im stumped and dont know what to do. ive double checked and triplle checked everything like a zillion times.
any help is greatly aprecciated.
Old May 23, 2004 | 03:18 PM
Vader's Avatar
If it was running at all, the distributor was NOT 180° out of phase with the valve train.
Can you supply a few more details of what started all this?
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
